Emissions Question
Joseph Herman
Vacaville, CA
Joe
Hello everyone. My son and I are working on a 1978 K10. Through the course of its like the vapor canisters have had the vacuum nipple damaged and the canisters need to be replaced. It is a duel canister setup. I have tried to search the part numbers to no avail. Part number 17056582 does not give me any viable results. The other part number, 17060868BC, comes back to a Corvette? Any help on tracking down replacements would be great. Thank you.
hoagster
California
K10, 1500
5.3l
Maybe this will help. Removed from my 73 k10. If you can't find a replacement PM me your address I'll send this one to you! I no long require smog. Hopefully this is the part you are looking for, if not post a picture!
And Welcome to the forum!
Craig 85
Nashville, TN
454/TH-400/NP205
hoagster
California
K10, 1500
5.3l
Your local parts store should have them also, below is from rockauto for $68, so you could probably get it from summit racing tomorrow for the same or lower price.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
In a pinch, you can also purchase either brass or plastic "barbed" nipples from your local hardware store (not a big box store like home deep hole), and then drill out where your broken fitting was located, to a size that will fit your new fitting. Epoxy it in there with 2 part plastic epoxy, and 10min later, you're good to go.
Welcome to the forums.
Was it all still connected when you got the truck? Reason I ask is that the purge system varied from year to year. My ‘75 has a dedicated port on the Quadrajet, and no other purge valve, but in some years there were external valves, or a valve built into the canister. You want it to vent periodically to remove vapor, but not vent all the time.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I Have a 87 smog truck.
All the engine equipment has been removed and sold to a gentleman in Colorado.
BUT, the canisters are still there.
If you want them, send a pm, because it's highly likely I'll lose track of this thread and won't ever find it again. Lol
if i still had/if i could find, i likely have one from a 78 k10 somewhere. unfortunately, it likely got tossed because its emissions and my gpa yeeted that stuff outa here.
can any canister work?
pduffyd
Melbourne, Australia
Yeah I just bought one for my 75 C20.
Hope this helps.
Dan27
lakewood colorado
Dan27
lakewood colorado
NOS GM #17056582 Emission Fuel Vapor Canister. eBay item number:325779613867. Aug 18, 2023
Doug Hampton
