Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
ok my brother in law has a 97 f150 with taillight problems.
turn signals, bake lights, reverse lights all work fine
2 bubls only, one for reverse only the other for brake.turn/park.
park doesn't work out back, fronts work, all the rest work no park lights in backl.
We messed with it today checking connections, had them working for a minute and put the lights back in and shut the tailgate, and no lights.
Worked on a plugin under the DS tailights, had power going to that connector but none at the bulb.
so we tried to skin it back before the connector, leaving it attached to the connector, and wire in a piece of wire from it to the other side of the connector, thus bypassing the pins inside the connector for it.
Nothing, as soon as you would plugin the connector you'd lose power to that wire, completely, with it unplugged it had power fine.
So we figured ground, we found the ground wire, did the same skin trick to it, and grouned it bypassing the connector, although when plugged back in the connector supposedly hooked them together and we had our splice on it to which makes double connections for both the park light hot and ground.
Well this did the same, plug in the connector, loose all power, unplug it and check and both the ground wire and the hot had POWER!!!!!!!!!! they would both light the test light up like power was feeding back thru the ground wire.
unhook it from one side or the other or the hot and it would not send power across to both hot and ground, if we unhooked the ground splice then only the hot had power on both sides of the connector with the connector unhooked.
Now with the hot splice unhooked and the ground splice hooked up, connector unhooked, nothing had power.
I think the ground is getting power fed back thru or bad ground casuing this issue, anyone else's thoughts? We are gonna try and work on it more tomorrow when he gets in from work.
