AaronW
- Mar 24, 2021
- MT
- Aaron
- V3500
All:
So I'm in the middle of rehabbing my 89 crew cab. I gave a guy 300 bucks for a running 1980 dually that had a good flat bed on it, which I'd then intended to cut down to the right size for my non-dually crew cab.
However...
I've got a friend who has a dump flat bed that came off a 76 Ford 3/4 ton, and he'd like to trade me that, for the flat bed I've got. Ok, so that's the backstory, here's my question: the dump bed seems solid enough, just needs derusted, painted, and rewelding on the mounting ears, since the frame it came off was apparently 1 1/2" wider than my chevy. It's missing the hydraulic pump, though, that runs the rams. Have any of you got any suggestions for hydraulic pumps that would work well, and won't break the bank? I'm seeing lots of 12v DC pumps around, but have also heard that that it's possible to set up a 120 AC pump with an inverter, so that then you've got a 120 v outlet handy, too. Any thoughts on these matters? Things I should consider that I'm not? The main beams that sit over the frame are going to sit slightly wider than the frame on my truck, as I said above. Any reason that would be a problem? Would it be smart to weld some cross members into the dump bed, to spread the weight out some more?
Aaron
However...
Aaron
