Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Looks like you'll either have to shave the wood in that area, or move the springs to the next hole in the shackles and trim the shackles. That 1" difference will raise the truck about half an inch.
If you use 2" you will run into the same problem as the original poster did. Either going with 1" might help or you will need to notch the rail under the bed.
