iflyfisher
- Oct 22, 2023
- So Utah
- Ken
- K20
I picked up some donor doors for my 73 K20. I noticed in taking off the driver door the upper hinges had a single washer shim while the bottom hinge had two washers under each bolt. I put on the donor door and the vertical gap along the B pillar was still a bit wide. I moved the hinge mounted to the body as far back as possible, but the gap is still too wide. The gap looks like it could use another washer shim. That would put three between the hinge and the door on the lower hinge and two on the upper. How common is it to need that much of a shim to get the doors aligned? I looked at the passenger side, and there are no washers between the hinge and the door on that side.
Curious
Curious
