Jak22099
- Apr 19, 2023
- Tennessee
- Jack
- K10
- 400 SBC
Hey ya'll;
I have a '84 K10 that I've been working on for a year or so and I've finally decided to tackle the AC. It was factory equipped, but the engine was swapped (400 sbc) and the hoses were never put back in and most of the components are in pretty rough shape. Decided if I want to do it right I should just replace everything, so I'm going to get new OEM hoses, accumulator, evaporator core, condenser, compressor, etc. and put in the fitting adapters and get it charged with r134a and the correct oil.
My question is - will the clutch fan be enough for the condenser or should I get an aftermarket fan to slap on the front of the condenser? I know most of the newer replacement condensers are designed to run with r134a not r12 but I've been getting mixed responses on whether or not I would also need another electric fan to ensure the condenser gets enough airflow.
-To be clear I'm not looking to replace the clutch fan, if it's really worth it for the AC to perform well I will just get one that'll go in front of the condenser between it and the grille.
If it is really necessary, what would ya'll recommend as a good aftermarket fan that will fit with OEM parts???
Any help appreciated!
