Diy4x shackle flip question
87scotty
Central il
Andrew
V20
5.7 for now
What position is best for the. Rear shackle? Straight up and down or leaning one way or the other? Pics if ypuve done it would be great
Swims350
Logan WV
none
I was told it needs to lean back at full flex so as it doesn't come forward and bind.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Mine has rearward lean but I installed 56" 3/4 ton springs, instead of the stock 52" springs so I had to move the brackets back to where the front bolt holes for the bracket lined up with the rear rivet holes of the old hanger in the frame. My flip kit is from Offroad Design though so more of an apples to oranges comparison. I don't think lean helps with ride quality, since the rear of the spring moves forward and back with compression/rebound. Once you get the old brackets cut off I would just bolt it in the stock location and see what you get.
87scotty
Central il
Andrew
V20
5.7 for now
Yea my rear holes where original bracket was has the hitch in the way. So minor cutting on brackets and nobody sells 9/16 bolts that are 5 inches long so not getting it done tonigjt
87scotty
Central il
Andrew
V20
5.7 for now
Is this to straight up and down i may move it foward to next set of holes. Its also sitting a lil higher tjan id like and i think itll come out right
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
The way I always learned was that you're shooting for about 22°. Vertical would make for a pretty stiff ride with the issue of possible inversion (shackle going the opposite way you'd like).
Swims350
Logan WV
none
how much lift did you get? and how long are those shackles?
87scotty
Central il
Andrew
V20
5.7 for now
6 inch shackles. it lifted that side maybe 2 inches which i took out 3/4 springs and put in 1 tons. Then when i move the hanger foward i suspect it to drop a lil more. Should be about the same as before im removing lift blocks for shackle flip.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Shift it forward one set of holes... should get you a pretty good shackle angle and the height will drop a touch.
Lu Blunt
Rye, CO
Luke
350ci
ORD 2.5" shackle flip with hd hangers
87scotty
Central il
Andrew
V20
5.7 for now
Done! took 3 trys to get it right. was in rear holes to start. Moved them foward tjen the shackle was at a 45 with no weight on it. So swaped left for right on foward holes and im pretty happy! Cant decode if i like the look more or less than the blocks but its done!
Swims350
Logan WV
none
what lift you got on the front 4?
87scotty
Central il
Andrew
V20
5.7 for now
Yep with 3 inch body so 7 total think when i drop the bb in it ill add an inch under the springs
Doug Hampton
