Different brake codes?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Had to replace a brake hose on the 81 GMC. The truck makes a HARD left turn whenever you hit the brakes, and once you release the brakes it takes a couple seconds before the truck would start to roll. Obviously, the hose has collapsed internally.
Once I got it back together no matter what, I can’t get the hose on the passenger to stop leaking. I have the banjo bolt tight enough that I’m afraid it will snap if I go any tighter. My plan is to replace that caliper, I did kinda gouge the sealing surface picking off the copper washer.
My question: the parts store is asking if I have a JB1 or JB3 braking system. They can’t tell me the difference, this is a Frankenstein truck, and the RPO sticker is long gone.
It’s a 81 GMC 1/2 long bed 2wd, originally 350 Olds diesel powered. The factory Hydraboost system is long gone.
Can anyone in readerland tell me what I have, or tell me what to look for? Thanks.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
it could be the threads if you replaced the bolt. check out the specs between jb1 and jb3 systems might be a difference in brake diameter which you can measure to find out. I had a wheel cylinder that had the wrong bleeder and the threads would not tighten up. todays junk parts!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Same bolt, I used the new washers that came with the hose.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
SquareRoot
Maybe the attached will help. Sounds like JB3 would be fine. Regarding hoses, I always remove the bolt and hose with the banjo fitting and promptly toss em in the dumpster. Then I replace them with AN adapter fittings and -4 stainless braided lines. Soo much easier to work with and find replacement parts.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Sounds like a pretty easy question to answer!! Power brakes or manual?
Now why couldn’t the counter help tell me that???
Auburn, Washington
I was gonna say buy both and return one.
Woulda made that call at the parts counter so I could complete the repair as intended when intended.
2manysquares2care
