Didn't pass emissions. Help?
Carb'ed Vortec 350
LMAO I'd love to
You do and then you have to pass even stricter emissions standards. Stick with stock, LS is for those that have money to burn to build something and then tinker with. Stock, you dial it in and run it.
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
How am I able to tell the RPMs without a tach? Is there a tool I can buy?
I passed emissions with all of your guys' help, but I still need to adjust my carb correctly now. I leaned it out as much as possible with the engine still running smooth. I got home and tried adjusting to max vacuum with the gauge and now it smells really rich. Maybe it is because I have a lot of vacuum leaks, so I might try adjusting it like how you said.
Some multi-meters can be set to read RPM with an inductive pickup. It's what I use.
You cannot tune the carb effectively with vacuum leaks all over. Timing needs to be done in combo with the carb tune as well.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
You can buy a used tachometer gauge that mounts in the truck and either mount it in the truck or just wire it up to give you the reading and leave it in your toolbox. You can also buy an old mechanics tach meter and get the RPM reading.
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
Yeah I’m never gonna ls swap it. I won’t have the money for quite a while. I’d much rather rebuild the stock 350. I guess I was dreaming lol. But come to think of it I’d much rather have a modded 350 than an LS.
hoagster
California
K10, 1500
5.3l
In Cali if you have the right model, no smog required and it's just as expensive to build the right 350 as it is to do a ls swap!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Or if you live in the right zip code there aren’t emissions tests, or any inspections for that matter.
Carb'ed Vortec 350
True, and true. If I lived in my home town I wouldn't have to do emissions testing on my newer stuff. The OP does live in an emissions testing part of Colorado, so an LS would cause the stricter testing.
I paid a little extra for a digital timing light with tach. It has come in handy quite a few times. Alternatively, you can look for older tach/dwell gauges, or get a used tach if you can find one.
You CANNOT effectively get it running right or tuned properly with vacuum leaks. The best, and probably cheapest, thing you can do to get it running right is find and fix all of your intake or vacuum leaks. Once you have found and fixed all leaks, THEN properly set up and tune your carb.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
deleted
Catbox
Peter
I have picked up used Tach's at the swap meets for as little as $5.
I have some speaker wire and alligator clips connected to one that is just for things like this.
Find the right places to connect it and you are in business.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
I'ed convert to fuel injection. The way they keep adding more alcohol to gasoline eventually carburated engines won't want to run due to all the carburetor seals getting destroyed by the alcohol.
Clayton
Sent from my SM-A705U using Tapatalk
Doug Hampton
