Daily A2B Tercel
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
How about a stripe?
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
How about a stripe?
She wanted blacked out...
So today got axles out and in...still need to put gear oil in... Also trans filter tommorrow.... & gasket....
Passenger side out...mine was 32mm vs the 1 & 3/16" in the youtube vid...
Ball joint 14mm
Gunk from leak on fenderguards...
Ps boot pass side issue...
Saw the front bumper wasnt really attached....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Immediately bolted the bumper on right
Saw this likely timing belt, oil pump, crank seal, oil gasket job....
Flicking oil on ac compressor...
Pretty gunky everywhere downI here
Hoping it aint rear main seal but just general gunk...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Crankshaft pulley exposed...
Another ps torn boot pic...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Axles in.... Still need fluid to gearbox...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Gotta cotter pin both sides, but am pacing myself as the scope keeps inceasing...
If you have this od button....
You likely have 18 bolt 4spd auto...
And need this filter....
Thoughtvit came with gasket, may need rtv, also think toyota runs oil plug gasket and trans plug gasket, so may need those... Really want to pressure wash it down and clean it all up
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Some random internet info...lotta pan options apparently... Guessed the right one...
Addressing the gear oil
Some.brand replacements amd capacites...
And the aocket chart as it took two parts store runs to het right socket size
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Saw a front brake option if I ever needed to upgrade...
Still gotta install this.....
Inner/ outter tie rod end links... Seem to have sway mounts but I dont think I have a sway bar. K&n oil filter but will likley do timing stuff first... Trans filter did come with rubber gasket... Ball joints and boots....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Sucky thing is I bought a harbor frieght pressure washer but after it sat like 6 mo the electric dont run , so its outta commission, and to late to return as they now have different models... Probly take a case of carb cleaner
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Dropped transmission pan...
Old filter
Thought I snapped one of the new filter in but I guess not... Pan back on... I typically use rtv sealant but this had a rubber gasket. I deel like I am chancing it, but will give it a shot. Oil pan I see they used excessive sealant so it will be more work with the razor blade when I get there...
Still got susp parts... I might have to try and rent inner tie rod puller tool
QBuff02
Central IL
Quincy
All I saw is a car with a bad spider problem, you should burn it immediately and find another car!!!:happy175:
nice little project actually..
Iowan
Iowa
Calvin
K1500
350 crate
Looking greasy! But what is a car with out oil everywhere?
Looks like you have a lot of work to do on it yet too, but I'm sure it'll be fun for the first 10 minutes.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Got the outter tie rods out still gotta get the inners, and ball joints but called it...
May need the inner rod removal tool but the tranny fluid was such a debacle filling it through dipstick my morale got low with spillage everywhere....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Yeah I had been putting off the under the hood work because I onew it xoyld get involved...
Lol .....10 minutes till something else goes wrong lol, if im lucky... If I just keep going system by system it should all pan out...
I may have overfilled my auto trans and need to let some fluid oit as I was reading the dipstick while she was up angled on jack stands...doh... Still gotta fill gearbox with atf... This will be another messy job..
Doug Hampton
