- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Yes, the exhaust manifolds on that engine will flow very well too. These intake and exhaust manifolds are other reasons why BBO makes great sleepers. Put some biggo old Cad mufflers on it and it'll be whisper quiet until the secondaries open up and then it'll roar like a lion. I know you have other plans, but just my analagy and what I wanted to do with my BBO, was make just that. A sleeper. BBO aftermarket parts are not cheap, not near as common either. So I'd upgrade the cam a bit, not a lot cuz I still want to keep the factory Olds bottom end grunt, and leave the rest pretty much stock since there's no huge benefits in going aftermarket anyway.I agree, nothing wrong with it! I sent those same pictures to my dad and he said the same too, looks fine, run them! Upon first quick glance too the head bolts look nice, I did NOT inspect them much, was just pulling them and looking at them as they went into the bag! I use ziploc & other bags to mark everything! Makes my life so much easier when doing this stuff.
I don't plan to part with the heads at all, I will be using them for this engine. Even on a fresh rebuild I would use them. As for the intake, I will be using that intake for now also and if the intake is ever updated I would like to find a dual quad tunnel ram intake for it. Again, mostly for the looks & cool factor.
The exhaust manifolds on this engine are actually from what I see pretty nice flowing too! They seem a bit big for stock manifolds, but the ports and the inside of them have some pretty dang good room in there unlike other exhaust manifolds I have seen. I still plan to run block hugger style headers though.
Then, if I wanted to something to sound mean and have lope to it at idle I'd be building a SBC or maybe a BBC. They're much cheaper to do and aftermarket part options are through the roof.
What people don't realize about Olds, when you look up specs and see something like 375hp on a 60's 455, it's a lie !!! A lie in the other direction where most will make claims it's 350hp and you're lucky if it's even 300-325hp. Olds lies and it's actually more. At testing they detuned the engines for specs, then later they could be properly tuned and get even more. Why? There were laws about max hp to weight ratios. Then what became more important was EPA and emission regulations. They no longer had to worry hp to weight ratio because the manufactures had to denut everything. Just like a 74-76 Olds 455 is gutless compared to a 68-69 455. Compression came way down, the E heads had NOx smog bumps that restricted flow etc. Id still run a 74-76 455 if that's all I could find, but I'd be sourcing a set of C heads or have to likely go aluminum. ORRRR, you can always trick even the Olds Gurus and run those E heads so they think you have a sled, but have those ported where you've ground out the NOx bumps and go with some flat top pistons to compensate for the larger combustion chambers to bring the compression back up and now you can run like a 68-69 and surprise surprise.
