Corvette servo
mjck5
wisconsin
mark
1986 k5 blazer
k5
Have been hearing about upgrading 700r4 with corvette servo, is it worth it? Also is it worth upgrading to the billet? Does that make the od better/stronger? It’s in a 86 k5 daily driver but used for towing and off road
NickTransmissions
Las Vegas
Nick
R10
Do the vette servo ($20) and drill the plate .093" if the engine/converter are stock. Run the billet 4th gear servo if you want to do some towing in OD on a level grade. Make sure you set band clearance correctly - see my vid on how to do so:
Darryl11
