Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
Ok guys I've been sanding new panels(rockers and cab corners inner and outer) and applying chassis saver on them in the areas you'll not get to again once installed to avoid future rust as much as possible.
Well I'm out of chassis saver, and it'll be a week or so before I can get some... sooo..
I have some summit dtm epoxy primer here and was thinking use it followed up by like rustoelum spray can or something?
What do you guys think as far as if that'd hold off rust as long as the chassis saver or not?
So epoxy and rattle can,
or
wait and use chassis saver/por15/rust bullet etc.
or
