granthendrickson
- May 30, 2023
- Oregon
- grant
- k10
What is the carb to mounting plate torque specs? I’ve been having a vacuum leak and so I tried to torque the nuts on the studs to 3 ft lbs and the studs stripped out and one broke in the mounting plate. The treads for the plate came out with the studs when I took the non broken ones out. I plan to get a new mounting plate as it’s cheap enough. The carb is a 1407 eldebrock.
