83chevyk10
- Nov 10, 2017
- Rising Sun, MD
- Caleb
- K10
- 350 SBC
Bought ball joints from 1A auto not sure if their brand joints are considered decent or not but money was tight and the Moogs were expensive. Anybody used them before? Anyways, both lower ball joint nuts wouldnt tighten they would only spin the stem on the joint. Put a floor jack under the drivers side knuckle and was able to tighten it fine, but having no luck with this method on the passenger side. I over torqued the upper adjusting sleeve (70 lbs) and was thinking maybe it was restricting the bottom joint from being able to seat properly? Went to remove it with the tool and it stripped the hell out completely... so my questions are, how the hell can i tighten the lower nut? And should i be worried about the adjusting sleeve being 20 lbs over torqued? And if so how can i remove the stripped sleeve and loosen the lower nut when the entire stem spins? Sorry if this is all confusing yall. Hard to put into words. Thanks
