can i use leafs out of a half ton pack in my 3/4 ton pack??
jason81k20
pennsylvania
jason
k20
So my k20 has a few broken leafs on both sides and I just bought a 1/2 ton parts truck. Could I just disassemble the packs and replace The broken ones with one's out of the 1/2 ton? they're the same width. I believe my broken ones are in the middle kinda
I searched with no luck
hirschdalechevy
norcal
rich
k-30
I have done that before with out problems , I mean the right way is to have a re arc done with the broken leafs replaced but you will have no problems making your own spring packs with the springs you have , I would get new center bolts before you start.
jason81k20
pennsylvania
jason
k20
Alright thats awesome to know, it'll save me about $400 bucks on new springs. What do I use for center bolts?
hirschdalechevy
norcal
rich
k-30
A re-arc at a spring shop with some springs replaced around here is around 65.00 each. As far as center bolts , our napa has all different legnths and sizes. I always get ones that are longer than I need that way you can line up the springs with ease then cut them off.
jason81k20
pennsylvania
jason
k20
Alright sweet thanks man!
yeti_87
