MikeB
- Apr 4, 2014
- North Texas
- Mike
- C10
So what they got it right forty years ago? You can't improve perfection or make a rounder wheel.
I like that cam for higher compression, and also its revised version (#24502476) with less intake duration for lower compression engines. https://paceperformance.com/i-62555...aft-gm-350-330-h-p-crate-engine-camshaft.html
Both have lobes that are easy on the valve train, and quiet, too. Even GM roller cams aren't over the top aggressive like aftermarket cams.
[/QUOTE]
That's always the best answer to the question, "Which camshaft should I use?"Rusty Nail said said:It's REALLY NOT the cam selection what is so important, OP.
Matching the parts TO EACH OTHER is far more imperative.
If folks paid more attention to compression ratio, heads, low restriction exhaust, and optimal ignition timing, they would be amazed at how much power their engine would make with even a stock or entry level performance cam. This whole idea about simply installing a big cam and expecting more power is just nuts, especially in a 4WD pickup.
