h3711.m8442
- Mar 8, 2017
- Fresno, CA
- Mitch
- c20
Hey everyone, im new to the forums and the new owner of a 79 c20 camper special. I joined to get your guys opinion on which cam to run with the heads im installing. ive read that many people like the voodoo 60103, but the c20 is heavy and unsure if anyone is running it currently on a modified 350 with stock converter.
I have a set of vortec heads currently at the machine shop for decking and machining for larger spring pockets and such for higher lift cams. also have an edelbrock 600cfm carb, and longtubes ill be throwing on.
I pretty much want the biggest cam i can get away with, without having to swap the converter, i want this thing to be able to get up and move. if any of you have experience or recommendations i will be highly grateful!
