Cam decision
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I most likely wouldn't completely agree with your first sentence, and I hope to discuss this further at some point... I do howeve really appreciate another new member with experience to share, and look forward to your posts. Welcome again..
Roller for the win!!!!!
Ronno6
South Mississippi
Ron
You might consider giving Willhoite's Cams in OK city a call...he fixed my up with a LT4 Hot Cam regrind for about 1/2 the price of new, every bit as good and can grind one to your specs.He may even be good with recommendations, not sure. But, wouldn't hurt to give 'em a call.......
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Good contact, thanks for the info.
noah_t
Kansas
Noah
So I found out which cam I have in the truck right now, it’s a pretty cheap summit racing classic cam, it’s a hydraulic flat tappet 288/298, lift is .444/.466 and the rpm range is 1600-5200, lobe separation is 112. I’m just wondering how much more performance I could get if I decided to switch to a different cam, thanks
kenn
detroit
ken
c10, k10
thumpr cams have the great idle your looking for "lope" come in different durations and lift to fit needs seems like they get the lope by a tight LSA 108 or 106 compares to a 112 or 114
2500 stall seems to be a basic number on converter remember the rougher the idle, vacuum can be greatly decreased power brakes can be an issue
68post
very, VERY, limited access member
Indianapolis
Tim
84 K30 SRW Silverado, 85 C20 C6P
454, TBD
If you call 5 cam companies - you will likely get 5 completely different cams unfortunately.
The World Sportsman II heads, (I have a set of them also), like as much lift as you can provide with all means possible in a streetable cam. This is where a roller would help,( if it's possible for you to utilize a roller), along with a stall & more gear.
I hope you don't have a stock shortblock, do you ?
4.56 is a great all around gear for 35's and a smallblock, my '83 K30 was 4.56/350/33's.
Those heads are similar to Vortecs in some aspects, much better intake flow than exhaust, and need to be cammed the same, except they can use far more lift stock and will still improve flow with lifts past .500"orc .550".
kodyg86
