spanky1205
- Sep 27, 2013
- Middle Tennessee
- Anthony
- V10
Sorry this is going to be long, I have read a ton of these threads and the first complaint from people who respond is they need more information, so I will just try to give it all in one shot. I own a 1987 4x4 that I plan to use as a daily driver until I give it to my son for his first vehicle. My goal is to have a good running truck, that I can go down to the local parts store and get what I need. I want to be able to pass a vehicle on a two lane road when I need to and sometimes pull a loaded 16' flat bed trailer, nothing extreme. The current engine is a SBC 350 with an unknown miles and cam, non matching smogger heads, flat top pistons with 4 valve reliefs, quadrajet carburetor, th700, np208, 3.08 gears, and 32x10.5 tires. I have good oil pressure so I have no reason to think much needs done with the bottom end and prefer to keep it that way unless something comes up. Once everything under the hood is working properly I plan to do something about the gears, for now they will stay. I did not build the engine so that is about all I can tell you, until I take it apart. I have had the valve covers off but I do not remember the numbers on the heads, I do remember reading they are both 76cc plain nothing special heads. The truck runs but, there is a vacuum leak that is caused from the intake not being bolted down tight to the heads. The previous owner stripped a bunch of the threads so now I can't tighten everything down properly. Rather than put money in those heads I would like to upgrade to vortec heads and serpentine belt system. The reason for wanting the new belt system is it will allow me to upgrade to the newer type of A/C compressor, I have read it works better with R134 refrigerant than the compressor that came stock on the truck, which needs replaced. I am also missing a few bolts/brackets and would really prefer to have everything on the front of the engine being held together correctly. I realize I will be going from 76cc to 64cc chambers and that will up my static compression to around 10:1. With all of that being said is there anyway I can use that combination of parts and still keep my power in the 800-5000ish rpm range by swapping out the cam? People on the internet say votecs can handle a little more compression with few problems, but I have no clue what "a little more compression" is and the only answer I can find is "it depends." I have also read I can run this combination with a 262 or 268 comp cam. I have looked up the cams and understand to a point what all of the numbers mean, but I do not fully understand what that will do to my truck. It seems like those cams push the power band too high. I realize I could get some aftermarket heads pretty easily but I am still left with the current configuration of belts with missing bolts / brackets. I realize to fully answer all of my questions you need to know a few more measurements to figure out the exact quench, static / dynamic compression ratio, and things that I have not even dreamed of yet. My goal is to have a basic plan and adjust as I get more information, is this realistic or should I be making a different better plan all together?
