SmokEaterHD
- Mar 11, 2017
- Missouri
- Chris
- K20
I’ve been working on my ‘75 K20 a bit and am noticing the horrible patch job one of the previous owners did on the floor. Literally welded 1/4” flat stock to the floor and spray foamed the rest. So I was gonna just cut the whole floor out, rocks, cab corners and the metal split at the bottom of the back of the cab and fix it all. However, I came across another ‘75 K20 that is complete except for the bed and drivetrain. Guy wants $250 for it and says cab is solid, but doesn’t have a title. Which if it is as solid as he says would be cheaper than trying to patch mine together. How does that work? You can’t just swap VIN tags off the cab and still be legal correct? I’m hoping to get a good cab, some interior pieces that are missing, and maybe see what’s in better shape on the other frame that I can swap to mine such as spring hangers, etc. Then just scrap the rest. I’m in Missouri if that makes a difference. Thanks.
