Building Locker rearend
bigge31566
GA
Ervin
Is there any threads on here to help build a rear end with changing gear ratio, or ring and pinion and installing a auburn gear locker. It is a 8.5" and 10 bolt in a 1983 C10. Do it need to get heavier bearing kit or can I just buy replacement bearings
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I've done a couple threads on rebuilding axles here, they're probably buried to the last couple pages of the Differential and Driveline section, that's been a while. If you take it on you'll need some specialty tools, like a hydraulic press, caliper micrometer, dial indicator, inch/lb and ft/lb torque wrenches, 450 ft/lb air impact, pry bars, center punch, hammers, etc. As long as you got all the necessary tools, torque specs and know what backlash and preload you need to achieve it's really not that hard.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
i just got done doing a rear diff with a used housing,, used carrier out of an other rear and used gears out of a different diff....... 1+1+1= time......
wasnt to hard,, but ya need lots and lots of oem shims to get it right......
i should have made a write up about it,, but my truck was down and needed to fix it asap..........:naughty:
firzty
