broken wing window swivel
jwmoses31
San Antonio TX
Justin
c1500
the swivel point on my driver side window broke so now it flaps around and whistles anyone ever have this problem? and how did you fix it if its even possible
My 85 K1500 has this problem. Haven't fixed it yet, but it appears to me, I'll be replacing the whole wing window assembly. I haven't really looked into a repair though since I have a wing window and figured it would be easier.
SlickGTP
Houston, TX
Is it at the top or the bottom? I had one fail at the bottom. Only way to fix it is to pull the whole thing out and weld the stud back to the window frame.
If it's at the top, then you can buy the rivets to put it back together.
Mine is broke at the bottom. The window just hangs there when open.
SlickGTP
Houston, TX
yeah... found out when I picked up my truck that mine had the same issue... there's a spring loaded stud that is attached to the bottom of the glass frame. Mine had rusted really bad and then broke off so the PO wired it shut.
I think I'm going to fix mine as they're the originals and all, but for the later style wing windows, I'd just replace the whole thing and just make sure the bottom pivot point is well oiled up.
SlickGTP
Houston, TX
Speaking of replacing... I have at least one for each side that are spares if anyone wants to buy them.
jwmoses31
San Antonio TX
Justin
c1500
i am looking for a drivers side wing window but i dont get paid till
the 20th how much are you wanting for it? and will it fit a 82 gmc?
SlickGTP
Houston, TX
Yup, it'll fit the '82. How does $25 plus shipping sound? I can take pictures of it when I get home tonight.
jwmoses31
San Antonio TX
Justin
c1500
that sounds good on the twentieth ill move it over to paypal plus shipping and as soon as it clears ill send over
SlickGTP
Houston, TX
Sounds good... Here are the pics. There's a small shallow chip near the latch and the seals are dried up like they are on most of them... So, I'll throw in a spare piece of glass just in cast you need it and knock $5 off.
Shipping should be about $15, which will bring the total to let's say $35. PM me when you're ready to send the money over and we'll get the ball rolling. :)
2manysquares2care
