83kid
- Apr 13, 2014
- Massachusettes
- John
- k10
Hi,
So theres this article which is in the first thread on the electrical and audio page:
http://madelectrical.com/electricaltech/brighter-headlights.shtml
As this seems like such a simple thing to do, im thinking of trying it.
They sell kits for it, but ive had enough electrical experience and experience with relays i think i can find my own way.
So basically how your going to do this would be to(For low beam, and then the same thing to be replicated for high beam):
1. Connect the power going to the low beam headlight to the low voltage switching wire coming from the relay
2. Connect power to one side of the relay load circuit (I forget the numbers on relays at the moment), where would this power come from? Straight from the battery?
3. Connect the wire coming from the headlight to the other side of the relays load bearing circuit
4. Ground the relay
So, is this pretty much how you'd do it most simply?
Is there anything wrong with how i said this could be done, would the 4 steps i put correctly work?
Thanks!
4. Ground the relay
Thanks!
