boltbrain
- May 1, 2022
- Montana
- Rick
- Chevy K20
My 79 brake pedal needs new bushings but the shaft, which also has the clutch pedal on it, hits the big clutch spring when I slide it back. The shaft is actually a bolt and the bolt head hits the spring. Can’t get the spring to come off, I pulled on it with vice grips but it’s stronger than I am. Moving the clutch pedal doesn’t get it out of the way. If anybody knows how to get that spring off I would sure like to know how. Thanks
