brake pedal has no pressure
Tycen
North carolina
Tycen
5.7 350 v8
I have a 1975 Chevy k10 350 I have bleed the brakes multiple times had some pressure moved it then lost all pressure. Pedal now sinks to the floor. I have noticed when I press the brake pedal I can hear a slight hissing noise that sounds like it’s coming from the vacuum valve booster or vacuum line. I think I’m going to just replace the whole thing but I’m 15 and trying to save all the money I can.
Fill the reservoir have a friend pump the pedal,while you look underneath for leaks all along the bottom of the truck,and behind each wheel.Any leak? Fix the leak . No leaks found? Buy a combination valve centering tool and a master cylinder. A booster will not make your brakes go away it will just make them rock hard.If you have a leak to the booster a bad one way check valve or leaky booster,by all means change it,but those will not make your brakes go away. A wet streak behind the master on the front of the booster is good indicator of a bad master cylinder.
Dmack
Central OR
Dave
If you can't see any active leaks, you may have a problem with the master cylinder. Either defective or needs bleeding. Did they ever work for you or just go out? Is it a project you just got and had no brakes?
arborvitian
