climb-101
- Mar 12, 2018
- montana
- seth
- c2 crew cab
- 6.0 LS
is there a difference in body bushing for the 73-74 crew cab trucks. i ordered a set from off road design but there not even close to working. the new rear cab bushing is 1/2” taller than the factory one. the others are the right height from what i can tell except for the ones under the core support which are smaller in diameter.
from what i find all the web sights, they list the bushing from 75-80 for the crew’s this makes me wonder if the 73-74 are different. another thing that makes me wonder if there different is because my B-52 kit dosnt fit the frame. i’ll call kurt on monday and see if he has any info on it. I was thinking it might be a difference in 2wd vs 4x4 frame but i have both and the frames where the b-52 mounts are the same shape and same bushings.
in the pics you can see how small the bushing is compared to the bracket. it is only about an 1/8” bigger than the hole. also you can see how the bottom of the B-52 bracket dosnt match the bottom of the frame at all.
bushing compared to the hole on the B-52
bottom of the frame vs the bracket
bushing tight to core support to see how much the bottom is off
