MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
So hey guys!
Turns out my mint 3/4 ton frame is slightly bent forward of the rear cab cross member.
It appears to be side sway. Where the front bumper horns are pushed side ways. It looks to be about 3/8" to the drivers side.
The frame is bang on from side to side height wise so it only appears to be twisted side to side.
You cant tell with the eye test that's its bent. Its only with a string and tape measure that you can see whats up.
Everything behind the rear cab cross member is nice and square.
There are a couple slightly bent cross members. The very front cross member where the proportioning valve is, looks like it is bent from having a chain or strap pulled from it. And. The transmission cross member is all bent up.
Its funny I didn't notice those 2 cross members when I bought it. Oh well.
So im thinking it rolled over in a V ditch and they had a good time yanking it out. Cause the rear end posi is freshly blown out in it too. And it came with 34" mud tires. Who knows maybe it got T boned ?
The frame is in such good shape rust wise though that im trying to figure out a cheap way to bend it straight.
Both axles are completely 100% parallel and 3/8" of dog track isn't really that bad but my OCD wont have any of it LOL
So Im not sure if 3/8" is factory tolerance or not. I would think its not.
Ok so how do I fix it with out buggering it up even more ???
I was thinking of tying the back half of the frame down and pulling from the very forward cross member to the passenger side. using my pick ups bumper up against the frame at the cab cross member to keep it from bending behind that spot ???
I was also thinking of pulling all the rivets and laying each rail down on the concrete with wood blocking, and then placing my pickups wheels on top of the straight portion of rail and then using the engine hoist to pull in the appropriate spots ??? Don't know if a 2 ton engine hoist will do it though ?
Also thought of something like that but using a bottle jack instead ?
I dunno ? Any suggestions ?
