Bending Hood
cstew47
colombia
craig
I'm doing my second hood repair on my 78 K5. I installed an aftermarket brace kit but that just moved the bend point further downstream. Is anybody else experiencing this issue?
I've had the same problem, and I also had the aftermarket brace. It got much worse in cold weather as the hinges got tighter.
This year I took the hood off and got it back to nearly straight, and I'm trying to keep it that way. I also made my own braces and they are longer than the aftermarket kit. It might just move the kink farther down again, but its work a try.
When you close the hood you need to have the hinges well lubricated, and you must push the hood back (toward the windshield) at the same time you close. This helps the hinge mechanism move and collapse easier so the hood can go down.
SDJunkMan
Black Hills of South Dakota
Jeff
I think every early square that I've owned had a kinked hood. Braces just move the kink. You don't want to make it too strong because that weak spot is a safety feature, allowing the hood to crumple in an accident instead of going atraight into the cab. Keep the hinges oiled and push back and down when closing the hood, and it will last.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
I had a slight kink, but was able to flatten it. What would be the recommended lubricant for the hinges. I know WD40 will not last. I bought some spray lithium grease and sprayed up the hinges really good. Is there something else I need to consider?
WFO
Texas Panhandle
I use Remington DriLube so it doesn't collect dirt.
78 Jimmy 2WD
Amarillo,Texas
GMC Jimmy
400?
Personally , I am quite fond of Slick 59 spray lube. I am a retired car hauler and used it for years on the chain ratchets on truck and trailer. If no where else, it can be found at Ace Hardware.
Lowered87
Oxbow, Saskatchewan
Adam
You could consider graphite spray. It is considered a dry lubricant. It will turn whatever you spray black but it dries instantly and works great for a long time without attracting dust. If you spray the pins in your hood hinge it will significantly reduce the force needed to close the hood so it should reduce the chance of being bent. Alternatively you could purchase aftermarket hood hinges that use a gas strut.
The owners manual on my 1980 says engine oil
Memaloose
Dolan Springs, AZ
Tony
I've found any lubricant works, some are messier than others but the most important thing is to LUBE IT REGULARY. You can wipe off the excess. I lube the door and hood hinges at least 3 times a year. Where I live it attracts dust but I also hose off under the hood at least a couple times a year.
I also found that when you check your fluids monthly, exercise the hood hinges. Open and close the hood several times, fully. The more you work the hood, the easier the hinges work.
Raider L
Shreveport, LA
William
@Bextreme04, is right, my factory maint. manual says use engine oil. And lube it on every place the hood moves on not just the main hinges, all those little places and they are all over the hinge. Also, when the back of the hood seems to have a problem going all the way down when you close the hood it indicates the hood springs have lost their strength to pull back on the hood. Replace them.
When I rebuilt my truck I bought a whole new front end including a new hood. That was the first thing I did was weld some .050" thick rectangles over the "crumple zones" And yes, they are there so the hood will bend in a wreck. But what causes the hood to bend in them is a dry hinge or a infrequently oiled hood hinge. When I bought my truck way back in '81 the hood was already bent and cracked to, bad. I remember every time I closed the hood I would have to walk over to the place that was bent and push down on it to get it down. I need to order a new pair of springs for my hood which I will be doing very soon.
I took the springs off my hood hinges and made a prop rod. The hood will still fold in a crash as designed,it was free but it is a heavy son of a bitch to open. But it doesn't bend now.
Bennyt
Surprise
Ben
IMHO, the braces that most people have shown below in a LMC picture, suck, and don't do much.
Brothers truck, Ecklers and others have a brace that works much better wrapping onto the sides and bridging the weak spot in the metal.
And of course, you have to lubricate everything and close the hood correctly by pushing back as you close.
For those that don't like springs; Wam Rods has a kit.
SirRobyn0
Rob
Of course my 84 does not have this problem. But my Dad had a 78 GMC from 80 until 98ish. He was very meticulous with maintenance but also a tightwad. So he did install braces on his hood as it was just barely flexing when he bought it. Because he was a tightwad he was a huge fan using used motor oil for lubricating things and gasoline for cleaning things. So he lubed his hinges with use motor oil out of a squirt can, seems to me he would give them a few drops of oil dang near every time he had the hood open. He did the push in and down from the center and by the end the passenger side was just noticeably higher then the fender. I would definitely say based on the number of hoods I've seen bent quite a bit, that any kind of lubrication will go a long way to help. I'm not endorsing used motor as a lubricant by the way, it's terribly messy and really not that great a lubricant. I guess my point is any lube will help over no lube.
Raider L
Shreveport, LA
William
@Bennyt,
Yeah, I've seen those in LMC's catalog. The gas shocks would work great except in all the years trucks that have the big hinges and springs. The Red truck in the photo is more designed for gas shocks because the small hinges are set back in the corners. My truck, '74 would have to have the gas shock put some where since I have to keep the big hinges but could loose the springs. I'm surprised someone hasn't come out with a kit for these earlier trucks by now. I've wanted gas shocks since I rebuilt my truck but didn't want to take the time to design something for it.
@Ricko1966,
Oh yeah, I know for a fact the factory hood weighs 96 lbs.!!
Bennyt
Surprise
Ben
@Bennyt,
@Ricko1966,
Wamrods does have a kit for the 73-80, I wasn't paying attention and posted the wrong pic.
Cantrell299
