Belt sizes
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Pull it and plug off the exhaust manifolds.
Sent from my SM-A705U using Tapatalk
Oh, that’s been done a while ago. I mean for the poor S.O.B.s that have to undergo an emissions inspection.
Turbo4whl
Downingtown, PA
Wayne
Aftermarket V-belts all have a common numbering system. The Napa number in the picture, 25-7435 is as follows:
The 25- is Napa's code for the Premium XL belt.
The 7 is the width of the belt **
The 435 is the length.. 43.5 inches
** A Dayco or a Gates number on the belt may use a different code for the width, but the last 3 digits are always the length.
And of course, any pre numbers on the belt refer to that manufacture's design. Like a Gates Green Strip belt etc.
MisterB
Northwest
AJ
GMC K2500 4X4
Changed the belts today. Turns out both belts ARE the same size. I was able to see the part number on both old ones and they match the new ones in size and part number. Got everything buttoned up and everything works great.
Sent from my SM-N975U1 using Tapatalk
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Go to the wrecking yard and pull the entire serpintine system off a Vortec sb. It's the best "less than a $100" upgrade you can do. Dump the ancient Vbelts.
Lol I was thinking the same thing.
Vbb199
Salisbury NC
Vince
Seems like too much fuss for something that works just fine
It really is, for something that works fine as it is (your truck)
At least on the tbi small and big blocks, the power steering pump is a TOTAL PAIN to get on and off.
SquareRoot
Nah! This more gooder!
highdesertrange
kalifornia
mike
k30
first thanks for the follow up Mister.
the thing with serpentine belts is if you lose anything you are DOA. with v-belts you have some redundancy. I still use my truck and I often find myself a fricking long, long way from any type of parts store. so I need it to be as dependable as possible. and if something should fail, a backup plan B is always welcome. beside the wow and the that's cool factor I don't get it. highdesertranger
MisterB
Northwest
AJ
GMC K2500 4X4
Since my old belts were still in pretty decent shape, I saved them and put them in the packages from the new belts, wrote "used" on the packages, and put them in my toolbox in the truck. That way if something breaks or slips off I can repair it to get myself home
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
When i did my engine swap it came with a complete serpentine setup. So switching would have been kinda easy. I ended up staying with my v belt setup. First of power steering and a/c lines will need to be changed or fabricated alternator is usually on the opposite side also. Second do the benefits outweigh the trouble. You always see that serpentine setup free up tons of horsepower yet i have not found where anyone has shown this with a dyno. I did find a paper on testing done on industrial belts and pulleys i think it was published by dayton? . I broke down different belt a pulley sizes and measured the frictional loss of each. Basically on average each pulley will cost you about 1/3 of a horsepower and that was for a v or flat belt. Take your typical serpentine setup, it will have 6 or 7 pulleys/tensioners meaning it's going to cost you about 2 to 2.33 hp from belt friction. Now a old v belt setup like on my truck with ac it has 9 pulleys meaning im losing about 3 hp to belt friction. Is it worth the trouble to gain one hp or less? Plus i like 2 belts on the water pump.
SquareRoot
Serp belts are cheap. $15 for my gates. Changing the belt takes a 5/8 socket on the end of a breaker bar or 1/2 drive ratchet. The act itself takes 30 seconds. Not so with v belts.
80BrownK10
Greenwood, SC
Nate
I might change them every decade, so I'm with the other guys, it looks neat but not something I want to spend a day doing.
Vbb199
Salisbury NC
Vince
Meh.
If the truck came with v belts, I'm not gonna take the time to convert.
Works fine.
If the truck came with serpentine, I'm certainly not going to switch to v belt.
If the truck has nothing and I have a choice like with my 502, I went gen 5 BBC serp setup.
Either or, 30 sec, the serp belt can be replaced, no big ****.
Whether it's a v belt drive or serp, keep spares in the truck like @MisterB lol
Meh.
Works fine.
I'm in the same camp. If it came with v-belts, that's fine. If it came with a serpentine setup, that's fine too. If starting from scratch, I'll install a later model serpentine setup.
Doug Hampton
