Auxiliary battery holder (drivers side) for my 76 GMC
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
Just giving a shout out to see if anyone has a diesel style battery tray they want to part with, need it for the drivers side of my 76 GMC so I don't have to run a mile of battery cable to the starter! I have an Olds engine in this truck, so the starter is on the drivers side.
Thanks in advance!! If I cannot find a used one, I will probably buy one from LMC truck, they have new ones.
If you have a spare "TRAY"with nbo bracket, could you use a driver side upside down and put a tray right side up somehow
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
Not really, I took the original one which was welded to & modified already and cut it up to make it work on the passengers side, it just wont. So I would rather just get a proper one and use it.
if you can find a local pre 73 square that gen, They had a box like mine I believe
ignore battery. tyhe tray has the open bottom and I think its a 72 or older
OldBlueDually
Minnesota
Justin
1976 GMC
C30
455 Olds
That is the same one my truck has in it right now.
Thanks for the link!! I checked on LMC and theirs is a few bucks cheaper.
if you dont mind a plastic tray, a menards battery tray or auto store proba have the same hbolt spots. the aux bracket is a pad and the base sits on it right
If so that would owrk. the OE driver not so much lol
Cantrell299
