Alternator tensioner-thing?
Hardly in photo, but still visible. Is there a p/n or a name for that bolt? I tried googling a few options but couldnt find any. its currently rigged with a bolt, washers, and a nut. It also appears to have bent the bracket a bit(might need a new bracket?). Id rather it be proper so when I put new belts on I dont have it putting torsional force on my belts like it currently is. Also, so it doesnt hit my alternator and seize it in place while the belt smokes. Dont ask me how that happened... haha!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I'm guessing the hole on the alternator is stripped, will most likely need a new alternator, then the bolt should come with the alt. If not I believe it's just a 3/8 bolt.
The alternator is threaded and its just a bolt? If thats the case, the original bolt might be gone and its just a replacement my grandpa threw in with washers... he was strange. A new alternator does not seem like a bad idea, this one struggles.
Poppy 87
Bloomingdale GA
R10 Silverado
If the alternator is okay, I'd use a heli-coil if the thread is damaged
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
A new alt is like 50 bucks and if the one on the truck is original or close to it might be worth it. But if the threads are fine and it works fine then no harm.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
It should have one washer.
Snoots
Roger
Jimmy Sierra
350 w/203
To be on the safe side, if you happen to ever get one from the boneyard always take that bolt with the alternator. At some time, I don't know what year, they changed to metric size.
Huh. Weird. So if i bought a new one, it might not work? I dont know what year this engine is out of. I could alwyas pulls the alternator and find a casting #
jjester6000
Illinois
Jack
C1500
The Metric system has always just been an inconvenience.
Especially on the GMT 400's where the inconsistency just pisses me off.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Not just the GMT400's. My 86 Sub is that way. I swear some moron used metric on half and SAE on the other half. No rhyme or reason to it either.
Very much a PITA.
Snoots
Roger
Jimmy Sierra
350 w/203
IIRC, all of the SI types use SAE threads and CS and AD types use metric.
AHA! Found 'em!
3/8 - 16 x 1.0"
or
M10 - 1.5 x 30mm
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
If you take in your old one they can easily match it up with a new one.
75gmck25
Northern Virginia
Bruce
I swapped a 94 amps V-belt 12si to get some more charge amps, and IIRC the threaded hole in the adjuster is metric. However, my alternator is from a newer GM car, not a truck.
Bruce
Bruce
Doug Hampton
