Aftermarket seatbelt mounting question.
BigT
Selah, WA
Tim
Scottsdale K20
I have a new set of belts from LMC, but as I'm sure many of you know, they do not mount exactly like the OEM belts, nor do they allow for the plastic cover to go back on with them. Does anyone make an adapter plate for the new belts so they can be mounted vertically and use the OEM plastic cover?
Tim
Old Guy Bill
KY
Bill
The ones I got from LMC had an angle bracket, it had to be drilled out to use the factory bolt. Take the belt apart and feed it through the plastic cover.
Bolt both ends to the angle bracket. The bottom of the plastic cover will need to be trimmed.
I need to get the right color spray for mine…
syd_pce
