oneluckypops
- Feb 6, 2011
- Sedalia, Mo.
- Luke
- K30 SRW
- 5.7 Fuel injected Vortec/ 4L80E
I came across a 350 that has been completely rebuilt, the only down fall is they never put the heads on it, and its been stored under a work bench for years. The motor was Free and the filled the cylinder walls with grease so the cylinders are still good just need to tear it back apart and have the block hot tanked again to get all the dusty grease out of the motor.
Heres my delima. I am wanting to clean this motor up and put it back togather and install it in the K30 just to get it on the road. The Problem is I do not have the Brackets for ANY of the accessories: Power steering, Alternator, A/C Compressor, none of it. I can get a complete pulley and bracket system off of an 89 3/4t truck that has the serpentine belt for free, I am curiouse if I can adapt it to my older 350 engine, or what kind of problems will I run into?
