jerula
- Aug 17, 2020
- Copenhagen, Denmark
- Jesper
- c10
Hi guys,
While I am working to fix my water temperature gauge, I am planning a bigger project.
My truck is a Chevy c10 1974. As it sits right now, the right front is about 2 inches lower than the left. The suspension looks stock, I am guessing it's just tired.
So I decided to look for a new suspension solution - I want slight lowering of the truck to improve handling. My goal is to improve handling a bit and have a truck that can still run with load and not bottom out on the suspension. I'm thinking a 2/4 lowering kit would allow me achieve this.
With my goal in mind, I started trying to find a kit that would do this and a nice set of shocks. Now, here I am, days later. Confused and not really knowing what I should go for. What brands are good and what are not? Do these lowering springs have a higher resistance than the stock to avoid bottoming out? Can I be sure? How do I know what springs to use with a given kit? Should I get a kit with a replacement leaf spring? Is my plan even realistic?
I really need some good solid advice. What would you guys do?
My budget is around $650.
In Denmark c-notching is illegal so I cannot go that way. Also I am pretty sure flipping the rear would also give me problems.
Thanks.
/Jesper
Thanks.
/Jesper
