Ac blower wiring
bcrupe
plainview tx
brandon
I have a 1982 Silverado c10 ac truck with no functioning blower. I don’t have power to brown wire 50 at the selector switch. I have traced the wire and it was hooked up to the trans lick down switch on the throttle pedal for some reason. Any who. Where is this wire supposed to hook to get power. I know the wiring diagram says something about instrument fuse feed or what ever but where is this on the actual truck? The wire isn’t long enough to reach the fuse panel and I don’t see where I believe it should connect. I can back feed power with my power probe and everything else works as I have already replaced the resistor and checked relay function.
75gmck25
Northern Virginia
Bruce
The low speeds run through the switch and the resistor pack, but the high speed uses the blower relay under the hood. If it’s on high speed the power comes directly from the power junction next to the brake booster and there should be an inline fuse in the wire running from there to the blower motor. Mine was the old barrel fuse holder and it drew so much power that it melted the holder. I swapped in a new 30 amp blade fuse holder and it’s been fine since.
bcrupe
plainview tx
brandon
Right I understand all of that and like I said all of that is working. I am wondering where the supply power wire to the switch panel plugs in under the dash because it’s not connected to anything right now and I’m not real sure where it connects into the instrument harness that the wiring diagram shows.
cj7_hvn
