87 V10 Wiring
Jason S
Deerfield Beach Florida
Jason Siracusa
Hello all. Finishing up build on 1987 V10 4x4 350 TBI. This was an abandoned project so I might be missing componenets. A two wire connnector on passenger side with pink/black [439] and dk green/yellow [428] wires not plugged into anything and there is nothing within its reachable range that I can see that it would plug into. Truck has headers, no pollution pump, aftermarket aircleaner, aftermarket a/c, dakota gauges. Need to know what this connector would go to. The wiring diagram I have says the [439] goes to IGN 1 PWR INPUT and the [428] to Cannister Purge.
On the driver side, I have a connector with a single greenwire, and a two wire connector with both wires going into it are green. Same question, not sure if I am missing a sensor or component. I cant find either of these connectors on my wiring diagram.
Thanks, Jason
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I would eat the green wires were factory A/C
Zelph
Nevada
Isn’t the single green wire for a tach signal?
Jason S
Jason Siracusa
Thats a possibility. Ill check that, I have dakota gauges including tach and its possible they have their own wire for the tach. My Dakota tach is working so maybe thats the leftover factory tach feed. Thanks.
blue900
