caden_cochran
- Sep 15, 2022
- Ga
- Caden
- v10 pickup
Okay so i have a 1987 chevy v10. Whenever i crank it up it will spit black smoke and misfire real bad and barely idle then after a few seconds it goes away and runs completely normal. I have replaced almost every sensor throttle bodies been cleaned new injectors, new iac, distributor is new and the cap, fuel pump is new ignition control is new coil is new map sensor is new knock sensor is new electronic spark control is new. basically almost ever sensor/module is new. Any ideas anyone i have zero clue what it could be but there may be sensors idk ab so ask away.
