Brownsquare
- Jul 4, 2021
- Wayland, Michigan
- Marc
- R1500
- 4.3 V6
A couple months ago I pulled my '87 GMC off the road for some basic repairs. The truck was leaking oil and trans fluid, and the clutch was definitely shot. What was supposed to be a week-long fix really snowballed! It hasn't helped that I don't want to go out and work on the truck in the 90+ degree heat and humidity! The good news is I replaced the rear main seal, the pan gasket, the flywheel, clutch, pressure plate, throwout, and re-sealed the Saginaw 3 speed. I'm just running into a couple of issues going back together.
They are:
While trying to eliminate all the oil leaks, I've noticed that the truck seems to be leaking from the oil pressure sender, which I plan to replace. There is another fitting just above it on the side of the block that also appears to be leaking. The only problem is I have no idea what it is! I've typed my fingers raw searching for diagrams of '80s GM 4.3s and none of them show it. I'm wondering if it has a separate pressure sensor and sender? Any ideas guys?
Second, before I took the truck apart I was having column-shift linkage problems. Every so often the truck would jam in 2nd gear. I'd coast to the side of the road, climb under, and fiddle with the linkage and it'd go right back in. A friend suggested I adjust the linkage, but the shift rods on the trans are not threaded or adjustable at all. It's a regular rod with a barrel fitting (pressed on?) at the end that pins into the side of the trans. Also, one of the barrel fittings MOVES (slides) on the shift rod while the other is stationary. Should this be happening? Seems wrong to me, but there's no way to fasten it to the rod. No jam nuts...nothing.
Help! Thank you BTW!
They are:
