84 C10 cluster swap
TMorton87
Richfield NC
Tommy
My 84 has a dummy light cluster and I’m looking into swapping for a gauge cluster. Is it a direct swap or what is needed to make it happen? Also what years do I need to get a cluster out of?
Use the search function there's lots of write ups.
84_c10_GMC
Alex
you should just be able to buy a replacement gauge that will fit where the light is. But you will have to change the oil sensor sending unit I believe.
1979 K10
Flagstaff, Arizona
Terrell
K10, K5
I just did this on my 86 K5.
You need to get another complete gauge cluster. The idiot light cluster isn’t setup for the gauges and you would have to do even more work by wiring each gauge instead of using the cluster printed circuit board.
biglex81c10
