84 c10 belltech 4/6 drop 9” rear - wheel / tire size
ESONE
Massachusetts
justin
370ci
Hello all,
As the title says, I have an 84 c10 with a 4/6 belltech swap (notched) and an early 80’s 9” rear end from a bronco so it’s a little wider at like 65” I think….. can’t remember. Either way I’m looking for wheels and tires and I’m a bit torn. I want 20’s for the look but worried about rubbing in the front however, this is an LS2 truck with single turbo so perhaps I should go 18”s with a little meat so I get better traction? Curious what you all think and what size / backspacing combos you would recommend for both.
c20suburban
