83 k15 won’t run in gear
cheesehead
Connecticut
James
K1500
My 83 won’t stay running. It’s got a new tank and sending unit. Electric pump, 350 with an edelbrock carb. It idles fine but once I kick it down it stumbles a bit but no matter how much gas I give it it instantly dies when I put it in gear. I’ve adjusted the carb and had it purring. It’s been sitting for a while since I’ve made other repairs. The only thing different is I installed a tach and I spliced into the tach wire to the distributor. Any help would be greatly appreciated
Urbanburban22
Colorado
Suburban SLE V1500
5.7 TBI
What transmission are you running? Any drivability concerns before this happened?
cheesehead
Connecticut
James
K1500
400 tranny, never had issues but it’s sat for four yrs only moving around my driveway to keep parts moving. The idle will hold steady for a while at 700 then drop to 3-400 then die out sometimes. Seems almost like it’s either choking itself out or flooding itself but in the back of my mind I’m thinking the new tach spliced into the distributor might have something to do with it
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Unhook the Tack See if it will run.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I guarantee your truck doesn't have a tach wire if it didn't have a tach.
fast 99
Spokane, Washington
With electric pump, check fuel pressure, accelerator pump.
Disconnect EGR if equipped, if that doesn't help reach underneath with fingers check rod for movement or hook up a vacuum pump check function.
HEI distributors, wire out of pickup coil will weaken. When vacuum advance turns the plate that circuit will open, engine dies.
cheesehead
Connecticut
James
K1500
It’s been raining all day, haven’t been able to do anything but yesterday I pulled the fuel line to rule out the filter and while cranking it the line flowed like a garden hose. And yes the distributor cap has three wires, one of them is a tach connection.
drumvirt
Virginia
Danny
C-30
Tranny? Torque converter malfunction can do that. What you described happened to my '95 Crown Vic a few months ago, but it would move a few feet in gear before it died. After a few more tries it wouldn't move at all. End of this week it gets towed to a very reputable and experienced trans shop for a rebuild. Maybe it's the trans.
Will it start and stay running in neutral? If so, put it in gear from there and observe.
When you put it in gear, did it move forward at all before the engine died?
Also, a loose ground wire anywhere can also stop your engine. Same for corrosion between ground wire and ground. GM issued a bulletin some years back that recommended (for older vehicles) checking ground wire connections for corrosion or loose wires. Vibration (like putting it in gear) can be enough to jiggle a ground and shut off your engine. I had that problem with an '87 Chevy that would die or stumble inexplicably and then go back to normal as if it was fine. I actually checked the ground wires by bumping them with a screw driver and nothing happened. Took the car to a top notch repair shop and they couldn't locate the problem even with their expensive engine analyzers. Their friend at the Chevy dealership asked if they could take a look at it. They couldn't figure it out. A week later the repair shop called me and apologized for taking so long and still not fixing it. They wouldn't charge me anything since they hadn't fixed it.
A couple days later it died right when I started it and put it in gear. I tried again and it started fine, so I raised the hood and even though I had already wiggled the ground wires a few weeks prior, I tried wiggling one of them again and the engine immediately died. I restarted it and jiggled the same ground and it died again. I had finally solved my problem.
Good luck and please tell is how it turns out and what it was.
ssxa
