700R4 Shift Selector U-Bracket Slot Orientation
crooney1189
FL
Carl
Does anyone have a good clear picture of the u-bracket for the shift selector on a 700R4? I need to order one and I want to make sure the slot has the correct orientation.
I don't have the original one to compare to, and I'm trying to gather the factory-style shift linkage and brackets to use in my LS swap with a 4L60E.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
This ain't a 700 but the one on my 700 looks the exact same.
crooney1189
FL
Carl
Do you have a picture of it off the shaft? That's the orientation I'm referring to, the shaft hole angle.
Every picture I find is of it bolted to the transmission where you can't see the mounting hole because of the nut lol
gordies78
