Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
86 and older 700 have a valve body without a forward clutch accumulator (also known as “auxiliary valve body”) I think they also and the smaller input sprag. The easy identifying clue is a thin casting line that starts above the oil pan rain, arches over the servo, and ends at the pump. The 84 and earlier are the ones to stay away from, they have the smaller input shaft splines, and other design flaws. It took a few years to work out all the bugs, but eventually GM got it figured out.
