6.2 diesel to 396 swap.
Dooley
North Coast
RW
V30
What's the deal with dual alternators on this one???
1986 M1008.
near half the truck electronics is 24V
CSFJ
1986 M1008.
So they converted to a gasser big block, and kept the 24v starting and charging system? That's a different way to approach it.
Dooley
North Coast
RW
V30
I needed the truck to be compatible with all my MV stuff.
CSFJ
10-4. That's pretty cool actually. I thought about putting mine back to 24v, but it would only have been for the novelty of it. That's cool that you have other trucks to use the system with as it was designed.
Dooley
North Coast
RW
V30
Yes, it still has full use with them.
CSFJ
lol. Impressive. That's a helluva nice collection.
Dooley
North Coast
RW
V30
A couple more I have although my wife "claims" the mule.
Derrick
near Milwaukee, Wisconsin
Derrick
I do believe that i want that collection lol. they all look great i am a little jealous about the k30 cucv
Austingulick
Austin
6.2 diesel
Can anyone link a decent distributor? I need everything... going from diesel to gas
beest
indiana
matt
I would go to local yard and get an oem hei, then put a rebuild kit in it. Cheap, easy.
Sent from my SM-G920P using Tapatalk
Or 1 of these cheap China ProForm drop in and go set ups. I have one in my 454. Worked great for about a year with very low mileage and the igntion module took a ****, but I've heard of many going forever, and heard of one the guy broke the shaft. It'll get you going though $40. Complete drop in and go. There's several different sellers, check ebay.
https://www.ebay.com/itm/Ignition-D...m=132242313634&_trksid=p2047675.c100005.m1851
If you ever run out of room for 1 of those, I'll find some room for you to park 1 here.
87scotty
Central il
Andrew
V20
5.7 for now
Need to find out what cam so you can find dizzy gear that matches
Austingulick
Austin
6.2 diesel
Okay so I’m caught up on the powersteering/hydro boost. So I cannot use the pump from the 6.2? How do I hook up the lines if I buy a different pump cause they don’t look the same at all...
dannyphx
