5 lug to 6 lug?
Cotas86
Phoenix
Anthony
picked up these 22" transports (6x5.5) for my 86 c10.want to swap axles rather then use adapters in rear. Wondering if k10 axels and drums will work for me?
ajd89
Central Michigan
andrew
Cool looking wheels! And as far as the axles pretty sure you can just swap the axle shafts out of a k10 for the rear but don' think the front is as easy. Im sure someone will give you a definite answer though.
Cotas86
Phoenix
Anthony
Thx gotta pretty good deal too wich makes them look alot cooler hahaha.Thats what im hoping for..... going with this for front
yevgenievich
Place
Name
Year
Model
Size
K10 axles and drums would work. Or complete rear end swap would be fine
4WDKC
Southern Florida
Kacy
for the front i have read you can use rotors from a 00 ish astro van with the 6 lug
ajd89
Central Michigan
andrew
When I had my c10 I looked in to doing this but never could fine a good answer in the front. I remember the Astro van rotors but thought that was for a rear axle disc breaks could be very wrong though. I like that kit there that would make it pretty simple just is nice to go the the parts store and buy rotors if you needed to instead of having to order them.
yevgenievich
Place
Name
Year
Model
Size
Gotcha.... so a k10 with a 10 bolt will work with my 10 bolt c10
that is correct unless it is 89ish-91. Towards end of production spline count changed in 10 bolts. But complete rear end will still swap in as long as it is from a square body.
4WDKC
Southern Florida
Kacy
Apparently it was the rear, just took a peak at rock auto and the 6 lug astro rotors are slip on like newer vehicles.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I think 01 or 02 up for 6 lug
350runner
tx
Ceasar
I have info for the front as i was gonna swap the front. Give me time and I'll look through my photos and find it.
Sent from my LG-LS993 using Tapatalk
jbahena95
