4.3 to 350 swap help
jl5464
pa
jim
r10
I have a 87 with a 4.3 tbi. I want to swap the 4.3 with a 350 that I have. The 350 is 78 with a carb. How hard is this swap. If I swapped the carb with a tbi would I still be able to use the same wire harness that is in the truck.
Same harness, just different mounts, dizzy, and prom.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Yup, all of the sensors are the same, accessory drive will work too, just make sure the rotation of the water pump is correct.
jl5464
pa
jim
r10
Thanks the motor came with a water pump,alternator,power steering pump and all the pullies. I was going get a tbi adapter plate and use carb intake and a tbi distributor. Really did not want to change heads and has a wieiand intake. Just want to make sure I got this I can use the sensors from 4.3 on the 350. Would I have to make any changes to harness or just change prom.
Cantrell299
