3/4 front axle
Those numbers aren't right. Iirc, 10 bolt is 3" and D44 is a little smaller. But a 10 bolt is certainly not 3.5", even the mighty 14 bolt axle is only 3 3/8.
tdub209
Tracy, CA
TJ
k20
maybe 2.5” and 3” then. i just used string to measure to tell which was bigger.
2.75 is sticking in my mind for the D44.
tdub209
Tracy, CA
TJ
k20
no idea what the numbers are. but the 10 bolt is definitely bigger tube size. so dana is going behind shop for something else some day
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I believe the 44 has a bigger wall thickness.
tdub209
Tracy, CA
TJ
k20
but smaller OD ? that doesn’t make sense. does the 10 bolt just have a lot of clearance between the wall and axle shafts?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I just know I read that somewhere when people were bashing the 10 bolt. I run a 10 bolt, a 30 spline one with a posi in it on 36s and a big block and it hasn’t broken yet
tdub209
Tracy, CA
TJ
k20
and you said to find the 30 spline outers from a late model suburban? or is there aftermarket brand stubs to get
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
No the 30 spline part is on the inside the outers are the same. The inner axle is bigger. 90-91 Blazer and Burb. 89 is 50/50
tdub209
Tracy, CA
TJ
k20
No the 30 spline part is on the inside the outlets are the same. The inner axle is bigger. 90-91 Blazer and Burb. 89 is 50/50
gotcha. so get inners from a 90-91
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If you read the whole thing it turned into a Marvin thread. Started out with facts and experiences and degenerated into name calling and butthurt.
Cantrell299
