- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
4.10 ratio is a very common gear ratio on the early 4x4 3/4 ton trucks like my ‘75 K25, but I’m not sure about later trucks. With 31” tires (245/75R16E) and a TH350 it runs about 2800 rpm at 60 mph, so still within a reasonable range.
You could bolt the suspension and drivetrain from my k25 onto almost any squarebody truck, as long as it has the high cab hump to clear the transfer case. My truck is a camper special 3/4 ton with the 8400 GVW package, so it has the 14 bolt FF axle with 4.10 gears, 7 leaf rear springs and 5 leaf front springs, front sway bar, etc. It’s very durable, and really useful as a work truck, but truly rides like a truck. YMMV
