1.4v at electric choke?
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Pretty sure that isn't right, should be 12 right? Anyone know off the top of their head which wire under the hood side of the fuse box is the one for the choke? I will just rewire it!
Sent from my SCH-I605 using Tapatalk
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
As I understand it, looking at the fuse block/firewall through connector from the front, the blue wire in the bottom right corner.
flyboy1100
UsA
me
k1500
Thanks. Haven't had time to check wiring diagram yet
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
The engine has to be running to close the oil pressure switch to deliver the source voltage (+12v) to the choke heater.
flyboy1100
UsA
me
k1500
if i unplug the wire from the choke i get 12.7 volts when the key is ON/Engine off, is it supposed to work like that too?
gonna go test it with the engine running
Boone83K10
Boone, NC
Benjamin
You should be getting 12 with key on/not running. You should be getting 0 when running or else the choke would stay shut all the time. Also, if this is aftermarket carb, you shouldn't be using the "choke wire" like how the factory was hooked. You need a different 12v source.
MadOgre
NA
NA
NA
NA
NA
Why?
350runner
tx
Ceasar
X2?
Boone83K10
Boone, NC
Benjamin
If you read the instructions, most of them say not to
Boone83K10
Boone, NC
Benjamin
Also, it says that you may not get 12v that way.
flyboy1100
UsA
me
k1500
Factory qjet. My understanding after watching some YouTube videos is the oil pressure switch will send power to the choke to open it as it heats up once the engine is running. It should by default spring shut. I have never seen mine move, but maybe it just hasn't been cold enough.
I still don't understand why I have 12v with the wire unhooked and very little voltage with it hooked up and engine off for both
Boone83K10
Boone, NC
Benjamin
It should be shut at startup in the morning. Cold to an engine is 100 degrees.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
"if i unplug the wire from the choke i get 12.7 volts when the key is ON/Engine off, is it supposed to work like that too"?
"I still don't understand why I have 12v with the wire unhooked and very little voltage with it hooked up and engine off for both"
If I'm understanding this correctly, it sounds like the oil pressure switch has leaked/damaged internally, and is not passing/shunting voltage. That was one of the reasons for having the 'idiot light' (Choke or Oil/Choke) in the circuit.
350runner
tx
Ceasar
Test this... put a 10 amp fuse inline with the choke power wire. If the fuse blows then either your choke is bad our the wire is shorting somewhere
flyboy1100
UsA
me
k1500
Inline from the oil sending unit to the choke? Just want to make sure I understand.
Doug Hampton
